What type of cases and cylinders does the 08 Superjet have?
61x cylinder ? and 64V cases?
What are a good porting and case modification to do for freeriding?
can anyone post specifications?
Or is it better to go with a larger capacity cylinder?
I will be using the following parts also
ADA 33cc girdled head
Novi 48 dual carbs
MSD ignition enhancer
Factory B Pipe
M16 reed valves and manifold
Not sure on which brand and degree impeller to use. Looked on the Riva website ahd they recommend a Slolas Concorde J (14.75 18.25) degree but sounds a bit high to me for freeriding, any advise appreciated?
Novi 48 dual carbs
Factory B Pipe
