1/2 Colored hose, where to find?
Hey,
Does anyone know a good source to get translucent blue 1/2" id colored tubing? Ideally i would like the color to match that of the stuff Fast Fuel Line and Blowsion sell.
Thanks.
That tubing has the same issue as another I found. The wall thickness is 1/16. Even the smaller 3/8 cooling line we use has 1/8 wall. Not sure I'd trust it.
You can browse this site and see if they have what you like. I use it and it's pretty good.
I can confirm using the 1/16” wall is indeed a bad idea. I tried it and 5 min after leaving the dock I was limping it back with more than one line melted off
I ended up going with the HPS through Amazon as it was slightly cheaper for 10' sections.
smokeysevin
one man with a couch
Houston
HPS makes nice hose, I also use Venair. Make sure you use smooth clamps though, if you use the open style worm clamps it will chew up the ends when you tighten it.
Sean
Sean
Yea I stick to Oetiker clamps wherever possible, so much cleaner, or the smooth worm clamps. I will say that when you are going this small with the smooth worm clamps I feel like they can be a bit bulky.
smokeysevin
Houston
On stuff that is easy to service or intended to be "permanent" I typically go with the pinch/oetikers as well. If it needs to come off and is a pain in the ass to get to it gets a worm.
Sean
