I agree.. could be voltage regulator..
I had same issue on a Kawi, swapped EVERY electrical part out with different ones, same issue, changed the voltage regulator, and bam.. worked.
I have a 2000 GP1200R 66V stator assembly in stock and just noticed you have a 1999 GP1200 65U which are quite different.
I do have the 65U lightened flywheels in stock for $125 outright but if you need an early stator coil I would check on eBay or the green hulk for sale section.
found one on green hulk hopefully the guy will hit me back?? looks like the tank has to come out to pull the flywheel ?? not sure I wanna take it that far apart right now but thanks for the offer. and the hulk refferal. got any parts for a 800 SXR??
