did everything now, new wiseco pistons, 82mm with .005 clearance bore, 35cc domes and compression is at 160psi ... kinda weird? since the 35cc domes run at 190psi no? im a little disappointed, not sure why, maybe cuz its not broken in yet? not sure what it could be
its ported
35cc domes
wrong Jessie, Most freestyle Porting does not touch the top of the exhaust port. only widens them, that being, there is no change in compression......
Paul told me it will effect the commpression
Yours is 85mm though, it seems odd that 35cc at 85mm bore would create 185comp to me or did I read that wrong.
Stock 81mm ported cyl w/ 35cc domes and stock squish (aprox .060) should make 185psi, but I always thought when you go up in bore the domes would be totaly different. Unles Paul raised your exhaust ports slightly when porting????????? Which IMO but contrary to popular belief is not a problem so long as you run high enough compression to compensate.
