- Fort Mohave, AZ
Selling my full ski. Hull is a 2013, according to Hurricane this is a one off ski using a gp1100 midshaft and a 2008 drives shaft, making the engine set back about 2" farther than normal.
-2008+ 144mm pump and shaft, new seals and bearings, new oem big hub impeller.
-2 ridepates, short and long
-Kawasaki 750 small pin
-Newmiller milled 175psi head
-Newmiller milled, lightened and true stator
-Factory Pipe manifold with Coffman's Sizzler pipe, dried out on the bottom with a flow control
-Bored single carb intake
-Superjet tank, internal fill
-RRD single chamber water box
-Yamaha start/stop switch wires to KAWI e-box
-Blowsion wide bars
-Torq grips
-Thrust single trigger throttle
-Superjet pole and chin pad
-Triple pissers
-SJ pole spring
-Blowsion limiting strap
-Pump primer
-Single SBN44, jetted to perfection. New GENUINE Mikuni carb kit, including pop off valve and springs
-Fresh blue diamond turf
-Fresh decals
-Fresh crank seals and gaskets. Leak down tested 10 for 10
Ready to ride, located in Apple Valley CA or Fort Mohave AZ
$8000
-Blowsion wide bars
-Torq grips
-Triple pissers
-SJ pole spring
-Pump primer
-Fresh decals
$8000
