Other 3 Primer plungers brought to life
Brake cleaner sprayed/ drawn into them by using a short piece of primer line to fill, fixed three non working primers today...I will always buy primer bulbs from now on because plungers style are unreliable imo. My Freak has a bulb style and they are so much better I believe.
Thought I share a fix that worked. Opinions ?
Vumad
Super Hero, with a cape!
St. Pete, FL
Know any bulb style that will fit into the OEM choke hole like the plunger style?
I want to switch away from a bar mounted bilge switch, but I have it because I didn't want to drill a hole in my boat.
I'm open to ideas to have the fuel selector, primer and bilge switch w/o drilling any holes, or making any of the existing holes bigger.
How long do you think they will last?
Seems inactivity is what makes them quit.
I went from bar mounted switch to removing it from the mount and moved it under the pole below chin pad with superglue. I kept hitting it on the bars so it had to go. Don't know about a smaller diameter bulb primer.
swapmeet
Brotastic
Arlington TX
Interesting, I would think the brake cleaner would eat whatever is inside and make it worse. Glad you got them working, I prefer bulbs simply because they're knee friendly.
Vumad
St. Pete, FL
Install the primer bulb in the engine compartment. Works for me but my ski starts easy anyway.
Might do that when this one :):):):)s out. The new one I just put on my ski is leaking. I stole the one off my X2 for now. Putting inside would free up the mount location for a bilge. It just concerns me to not have primer avail in the surf.
My bar mounted switch is on it's way out too. Not looking to spend another $70, or $35/yr at the rate these last.
I only dislike the plunger style because I took one in the knee, after that I only mount them inside the hood. Then a bulb cracked sitting in storage in my shop and leaked about 2 gallons into the tray, it's common, should probably be changing my mat every two years anyway.
