Rushford_Ripper
- New York
I usually run 40:1 in all my skis even if 50:1 is called for, I like the little extra. I now have a Ada head installed and with the higher compression, wasn't sure if I should be running it now at 50:1. Does it matter that little bit with higher compression?
