- West Michigan
I have read so much about the weaknesses of the stock Octane carbs so I decided to try another setup. I had a couple Keihin 42mm Race carbs from a Kawi 750 I had. I took the throttle shaft out of the stock octane carbs and installed it into these to get the right spacing. I then port matched the intake mani to the large carb bore. Has anyone tried this setup? How do these perform compared to the stock carbs? I am also running dual pulsers and V-force reeds. Any jetting suggestions?
