44sbn jetting help
SW UT
So I've never rejetted my carb, and don't know the jetting in it. I've always gotten it to run right by just messing with the adjustment screws. I bumped the compression and simultaneously moved states for school so had an elevation change and the ski isn't running very well, so I think it's time to properly tune the carb and do a rebuild.
I mostly ride around 4300ft elevation. Mikuni 44sbn carb, west coast intake manifold, (unknown brand) high compression head further milled to 190psi, and a factory pipe. If it matters I also have nitrous oxide, though it's a wet setup so provides it's own additional fuel and it only gets activated at WOT when I want to use it.
As said, all the "tuning" I've ever done was to mess with the screws and I felt like I could always get the carb dialed that way--I presume that's an incorrect way to tune it but if I don't have to rejet and messing with the screws is fine that'd be awesome. We have another 650 that has a 44bn and all we do is adjust the screws on that and it runs like a champ at this elevation and before at 5500+, that's why I'm curious if I actually need to rejet. I've been reading through the sbn manual: http://www.mikuni.com/pdf/sbn_manual.pdf Is rejetting easy, as in can it be done in the parking lot or on the beach? It looks like you need to open the carb up quite a bit to get to the jets, which seems like it would make tuning take even longer than it already does...
Thanks for any advice.
