SXR 6.6 Gallon Fuel Tanks
I had a local guy request a larger fuel tank for his SXR and was kind enough to let me borrow his ski along with several different pipes. One-off tanks are too expensive, so I made a batch of 10... I may make more if there is any demand for them.
The tank is constructed from laser cut and CNC bent corrosion-resistant 5052 aluminum and fully TIG welded with a capacity of 6.6 gallons. It keeps the stock external fill tube while also having an anodized billet aluminum fuel cap (with lanyard!) for internal filling as well.
Pickups are brass 90 degree fittings with stainless steel pickup tubes, relocated and lengthened vs the stock pickups so that you can actually pull all of the fuel out of the tank. You can choose between two full depth pickups, or one short and one full depth for the reserve option. I can also add a 3rd pickup for triples if you desire.
The only modification required to fit the tank is to trim the foam. It will drop right in and use the stock straps. I would also recommend running inline fuel filters (a couple bucks at any autoparts store) as the pickups do not have mesh around the inlets. It will fit with any pipe that will fit with the stock tank, including the Factory wet pipe, C4/Nynja chamber, stock exhaust, etc. Will also fit with 1100s.
Pricing is set at $429 + shipping.
Options include:
- Choose from black, blue, red, and silver anodized billet cap
- Stock pickups, dual pickups, or triple pickups (3rd pickup is +$10)
- Powdercoating +$30
- Fuel level sight tube +$10 (opaque nylon tube secured between brass 90s with Otieker clamps)
i like this but i need to know if it will clear my coffmans 1100 pipe ?
That I am not sure of, it looks like it is awfully close to the stock tank. Do you have to deform the stock tank to get it to fit? There is a good chance that I will be making a large tank specifically for the 1100s too that will have an ebox mount on the front; I may increase the clearance in that location. It would likely be a month before I have those ready though but I've got a list of potential buyers lined up for it.
Work of Art
Sent from my SAMSUNG-SM-G930A using Tapatalk
Thank you!
i dont have it in my ski because it hits the tank ...
i have a small fortune tied up in this pipe and cant use it
This is the only pic I can find that shows one stuffed in there with a stock tank. I think I could modify the tank to fit but I wouldn't be able to guarantee anything without more pics...
