Did a compression test. 60 psi in the rear cylinder... After riding I saw a line that was disconnected that went into the carb. I went online and found out it was a pulse line which is used fuel system. I pulled the plug and that side was lean. The other side was rich. I guess this is why I lost to the blaster, b/c I called up the dude I bought it from and he said something was wrong and I should do a compression test. He said the SJ when he had it outran his 55mph couch. The front cylinder has around 150psi of compression. I don't know how long the pulse line was off either...
I pulled the head and there are burn spots on the top of the piston. On the side of the piston/ piston skirt I see some scoring. With the pulse line disconnected, it did not get the fuel required. :cry: Also it looks like the crank is burnt on the rear cylinder because the front cylinder does not have that type of darkness.
So, I guess I'm going to get a machine shop to check out the cylinders to see what size pistons I should get if I have to go to the next size or not. It cranks up fine and everything, but low compression on the rear cylinder. Pistons rings don't look bad either, but I wouldn't know...
Does anyone know what those zig zag looking lines on the side where the pistons go into are? I bought this SJ modified, as most of you already know. I guess I will need a topend kit now... Does anyone know if the pistons that are in there are 760 pistons? This is my first jet ski too. :-( Is the crank burnt/messed up?
