- Washington
I’ve got my 95’ blaster torn apart right now and trying to get it ready for the summer. I got a few questions about boring the engine and re-jetting, etc. I’ll let you know what I’m running and the whole setup I have so you have a better idea of what I’m working with.
-61X bottom and top end
-ADA girdled head
-riva red pipe
-single 44mm carb with pro k filter
-lightened stock flywheel
-zeeltronic ignition with an msd coil
-9/15 skat impeller
Bore and dome size??
Right now I’m trying to decide which size to bore the engine out to. Can’t decide between 83mm and 84mm. The Ada head has 37cc 701 domes at the moment and I’m curious what I’d want to run for the 83 or 84mm bore. I normally ride river mouths and tidal areas with sloughs, as well as lakes. I like the bottom end quickness but I need a setup that’s reliable enough to go full throttle for a decent amount of time. Pump gas mainly but occasionally running av gas if I’m not traveling.
Porting?
I‘ve never ported an engine before but I’m pretty good with a dremel and/or die grinder and I’m sure I could figure it out myself if I have a template. Is it worth it to port the engine for what I’m looking for if I bore the sleeves?
Crank?
Should I look into a different crank when boring out the cylinder or will my stock crank be fine? I have about 3 years of riding on a stock crank right now.
Jetting?
Say I go with 84mm bore and 37cc 760 domes, no porting, stock crank, and running pump gas. What are the jetting specs that you‘d recommend starting with?
Thanks
-ADA girdled head
-riva red pipe
-9/15 skat impeller
Porting?
Crank?
Jetting?
Thanks
