61x question
Ok, thanks! I'm thinking about buying and want to check future options before I buy. Needless to say, there aren't many
blasters with 62t motors around.
A local guy is selling his -96 with a single cargo (44) setup.
I asked him if it's the original motor and he doesn't know.
Would somebody slap a single carb on a 62t case? Seem's odd.
TheCoz43
Jet Surfer
Pismo Beach, CA
It may have an aftermarket manifold. It is not odd. Some people like the single carb instead of duals. It is easier and simpler to set up. Which is it a 61 or 62 case?
TheCoz43
Jet Surfer
Pismo Beach, CA
It is easy to tell by looks too. If you got a pic of the intake area I'm sure we could figure it out, but I wouldn't let that stop you from buying. A single 44 is just about the same as dual 38's IMO.
The 96 Blaster was a 62t case and should be a dual carb setup from factory. However some of us run single carbs on the 62t case. The 62t case has more to offer as far as intakes and reeds from the aftermarket. The single carb is easier to setup and tends to use less fuel. In theory, the single 44 should have a little more throttle response than the dual 38s due to the velocity increase from choking down the airflow. I have not tested yet, but once I get my single 44 setup tuned I plan to switch back to my dual 38s and tune them to see what difference I feel between the two.
Kurtis
Vegas
My 61x had dual carbs it never ran right even with the best carb tuner around the cases just Arnt designed for it, I took off the dual 44s and put on a single 44 and it ran perfect. Maybe find a "wet jet " intake they came stock with a 46 and those seem to do well
Wetjet had reed spacer with stuffer and it ran a 46 that's what I'd look for if I was you. Then throw some reeds on it
Never personally ran the WetJet manifold on one of my 61x cases, but I have also heard a lot of good things about that setup. It is an improvement over factory Yamaha manifold for sure.
Kurtis
Quinc
Buy a Superjet
California
I do not know how good the nadaguides are as a reference, but it shows the Wetjet Kraze with the 46mm carb and reed stuffer as having the same HP (75) as the Wetjets with the stock 61x intake and 44mm carb.
I use NADA on a daily basis with my Job for various types of collateral on loans, and I wouldn't trust it completely for options and specs.......values only!
Kurtis
player1
Player1
USA
Single carb 61x stock engine is 10HP off a Dual carb 62t stock engine. I have a single carb and done every bolt on possible. it rips.. but then i rode a 62t with every bolt on on possible. um yeah, I should done the case mod to dual carb or got a 62t straight up.
Quinc
Buy a Superjet
California
Have you done the Wet jet manifold mod?
Here are a few thoughts on the differences, and it really just boils down to a few things. The 62t cases have better aftermarket support than 61x. There are quite a few aftermarket intakes available for it from duals to singles, crossover or no crossover, and the OEM even has a Dual 44 setup that will bolt up from the 760. There are more options for aftermarket reeds Boysen and V-Force to name a couple, as well as Intake spacers to change the angle of the intake. The 61x only has the WetJet manifold and I think R&D mad the dual setup for it, and limited to the stock reeds, WetJet reed setup or Boyesen.
As far as the Dual versus single carb, or even larger carb sizes go, it comes down to Velocity of air versus Volume of air. Each will create a slight change to the power band, and of course the more volume will tend to create higher Peak power number until a point. Basically, the more air you can get the more peak power you will make but there is a balance to be had here as velocity is very important as it relates to the speed the air is traveling. Ultimately getting air into the port fast enough to get the most air into the cylinder before the port closes is going to build power. If you you open up the air path so much that is slows the air down, (Think thumb on a garden hose here) then you will not be able to fill the cylinder efficiently, the same can be said in the reverse as chocking or restricting the air path too much will also not produce the volume of air needed. There are tons of theory and calculations that are far above my knowledge to figure out the optimal sizing, but the basics are laid out. The rest of the combination of parts and modifications to the engine will also determine the optimal size, because as you open a port up with porting, you are now effecting the Volume and velocity of the air flow at the entry to the cylinder. This is why I trust the trial and error of previous builds and the knowledge of the true engine builders out there by following build threads and just reading what works or doesn't work on setups similar to mine. I hope this helps.
One thing to remember is.....More air in also equals more fuel required to reach a stoichiometric mixture, so fuel consumption does increase.
Kurtis
