- Pinckney, MI
Hey guys,
I was riding my 61x SN all weekend, and on Sunday after riding for a while, it wouldn't restart, the battery was nearly dead.
I pulled open the ebox, and found the following:
Resistances:
Green 1 to green 2: 1.1ohm
Green 1 to ground: 550k
Green 2 to ground: 550k
Voltages, engine running at idle:
Battery Voltage: 12.3Vdc (12.5 not running)
Green 1 to ground: 14.5Vac
Green 2 to ground: 9Vac
Red wire from Rectifier to ground: 4.8Vdc
Recommendations? I'm thinking it's probably the stator (due to imbalanced voltages on the green wires.) Would this explain the lack of voltage out of the rectifier?
Thanks
-Rob
Resistances:
Thanks
-Rob
