61X to 1100 Yamaha Conversion for Jet-N-Spray
RoyalFlush@PCB
Shootin' The Crap
PCB
Alright all you triple cylinder swap gurus, I have a Jet-N-Spray with a 701 61X and I have a donor 1100 Wave Venture. Theoretically, shouldn't this be a relatively easy swap using the ADA Racing kit? I have TONS more room between the front of the 701 and the gas tank. I might encounter some clearance issues with the 1100 exhaust and the Jet-N-Sprays hood, but I think that will be easily resolved. Thoughts?
dfw
Make sure to use the large diameter exhaust hoses and muffler. You will also need a high pitched impeller for the 144 pump. It needs to turn no more than 6900rpm. Ideally install a 155 unit, that will perform much better. Expect a noticeable increase in acceleration and a slight increase in top speed. If you have no experience doing these kinds of swaps it will take some patience and time to do it well.
RoyalFlush@PCB
Shootin' The Crap
PCB
I'm considering the 155 pump, as I already have one and the donor ski does as well. Thanks for the tip on the exhaust system!
I used a Solas swirl (16/23 I believe it was) on my stock 144mm pump on my Waveblaster 1100 conversion and it works great. This would be a good option for you if you don't want to swap a 155mm pump in.
