62T 760cc / +4mm Crank 800cc Stroker Engine / 44mm Blackjack Carbs
PA
Waverunner 62T engine, new 760 cylinders with +4mm stroker crank with 800cc displacement. Blackjack 44mm carbs, R&D intake, ADA head porting and build done by CPT, less than 30 hours on build. Bought for a project but never used. Waveblaster 1 factory b pipe sold separately for $1050. Will include lightened flywheel. Located in East side of PA. Asking $2200 for engine/carbs/flywheel. Also have Zeel programmed for build.
