- Grand Rapids
What do you mean keyway?If you warm the jb weld up before you pour it in it will flow alot better, be sure to make a keyway in each section to prevent it from coming loose. Clean parts well with acetone.
oh so you grind a small notch in the case near the top?A small notch in the case of each area to be filled, parallel to the cylinder gasket. Prevention of it popping out, mines done like that, may be overkill.
Alright i got what your saying. THanks. So i should use jb weld? Also does anyone have any used Girdled heads they want to sell. Thanks.Exactly. Nothing to do with what zero said. Just to make sure your epoxy will never come loose.
if you dont mind me asking what is the reason why we use we fill in with epoxy anyways?
