- Cass Lake, MI
I Did a search and never really found what I was looking for. What kinda gain is to be expected from properly ported 62T cases?? I know every mod combo is diff. and the ben. from the ported cases will very with the mods done (and amount of case porting) but as an example, on a 701 with mods listed below is there that much of a power gain?? Say you have 2 of the exact same combos as below with the exception of Ported cases on one, will you notice a BIG diff?? -Thanks-
Freestyle ported 701 61x cyl
185ish psi
B pipe
dual 44 or 46mm carbs & after M. reed setup
prop, msd enhancer, etc.........
185ish psi
B pipe
