- Northern California
I'm selling a 62T Yamaha 701 engine with Dual Stock Mikuni 38's. This is an amazing motor and I'm said to see it go. This engine and carbs have been tuned by the Ski Clinic and It was actually the owners motor at one point. Only selling due to just buying a new ET 967. Willing to ship anywhere AT BUYERS EXPENSE. Will not separate, Carbs and Engine go together. I am also selling an OEM 144 pump, if you're interested I posted another listing about it and is linked below.
Selling for $1,350 OBO
- Engine came from an 08' Superjet
- Engine has a 83mm Bore witch converts to 751cc
- Engine comes with Stock Intake, Stock Reeds, 2 Stock Mikuni 38 carbs
- Don't know the exact amount of hours, but I have never had a problem with this motor
- New Crank seals were just installed and has 0 Hours on the new seals
- Compression on both cylinders are 165psi
- Also comes with 2 Carb Adapters which are already installed, and 2 Prök Air Filters
- Carbs have had their choke plates removed and holes filled in
- DOES NOT come with Bed plates, Flywheel cover, Electronics, Exhaust Manifold, Starter, Bendix, Flywheel, and Coupler
