- Elk River Mn
Bought a used 62t for an older sj. Starts up and idles fine runs fine. Disassembled to check some leaks around header and the mag side piston has some 2 chips in top edge of piston that pinged around in the head a bit. First off what could of caused that? Secondly just thinking new pistons and rings should be good, cylinder walls still look good.
