- Stockholm, Sweden
Hi! I am finally getting around to replacing the engine in my RN. Last engine (6m6, with a 750sx intake flange welded on by the previous owner) had a bad crank and tore a rod, smashed a hole in the crankcase, kept running on one cylinder for a while until finally properly locking up. So more or less a total write off.
As I am located in Sweden where the stand-up market is very small, parts are few and hard to come by, so I want to try and work with what I have. There are also no machine shops with knowledge about these engines that I know of.
I have the following parts at my disposal
My idea was to use the 46mm carbs, b pipe, aluminum waterbox and msd ignition on the stock short block, together with the stock flywheel and stator. For this I have some questions;
- Stock 62t short block from ebay with ~150psi in each cylinder
- Dual 46mm carbs with intake and stock reeds
- Factory B pipe
- Ada girdled head (one of few parts which can be salvaged from the old engine if I select to buy a new dome for the affected cylinder)
- MSD ignition (CDI and coil)
- Factory flywheel/stator
- Aluminum waterbox of unknown brand which sits next to the battery
- I am thinking that 46mm carbs is a bit extreme, but as that is what I have available, I would prefer to stick with them. Any opinions here? Would it be necessary to tap a second pulse fitting? Any recommendations on jetting?
- Is it worth it to buy a new (or two) dome(s) for the girdled head? Which size? Remember that shipping and taxes will probably at least double the price.
- How would you route the cooling if using the stock head? The ada head? Would you run dual cooling? The waterbox has what looks like a fitting that opens when the pressure is high enough, can provide pictures when at the garage.
- Is there anything else that you would change out? Keeping in mind that parts are double the price when shipping and taxes are paid and shipping usually takes multiple weeks.
