62T stator+flywheel on 61X e-box?
i have a 61X e-box with a rev-limit-modified 62T CDI in it, which is currently running with a 61X stator/flywheel combo in a 62T crankcase.
Can i swap the 61X stator/flywheel combo for a 62T combo? I know i can´t mix 61X and 62T stators/flywheels.
uk
Yes the only thing you must match is flywheel to stator everything else is compatible
Sent from my iPad using Tapatalk
mike b
California
This is just what I was trying to figure out. Sorry to thread jack but i have a 61x motor and all the electronics are stock 61x to my knowledge. I have no spark and wanted to try a 62t CDI and coil as I have those on the shelf. So I won't run into any issues installing a 62t CDI in a 61x ebox as long as the stator and flywheel are the same?
uk
Very unlikely to be your cdi I check your earths first, if you have a multi meter check you have power to the coil when you hit start button , then check stator readings
The 6M6 , 61X and 62T cdi's are compatible and interchangeable with either f/w stator mix as far as I know and have done. Just one small point: The gender of the white/red stripe wire is different . You can change that. MSD enhancers are furnished with a small adapter pigtail for that reason.
