- sask, canada
I bought a 97 waverunner 760 yesterday for cheap...I knew that it had a piston issue, but it was cheap and I haven't torn apart a Yamaha engine yet so I wanted to experiment on this before I tear down my xs865. Did a compression test before tear down and found 130psi in pto side cylinder, but only 30 psi in the other cylinder.
Looks like the one piston ring let go and caused all the damage.
The cylinder wall has 2 small gouges, and a couple of the ports are dinged up a bit. Think it needs a resleeve or can I just bore it over?
Think it's worth it to rebuild it, or should I just scrap it and part it out. The original plan with this ski was to do just that, but the hull is mint, actually everything about the ski is mint if it weren't for this piston ring.
