650/X-2 650sx dieing problem wtf shark
Uh, try to rephrase that... Its dieing when?
If your saying constantly, then its probably a fuel issue. I would check the fuel lines for blockage, then tank for debris. Then rebuild carb or at least clean it out.
Take apart you start stop switch, the spring in my stop button rusted away so it was partially staying stuck almost off and it would randomly shut off like ur describing but start right back up
iangdesign
Cats, lots of cats!
United States
my ski is just dieing out whenever what could it be?
Start with the basics...if you have crummy old fuel lines, replace them...install an inline fuel filter. If your carb looks like it needs a rebuild, rebuild it. Check and replace the spark plugs, make sure they are gapped properly.
I had this problem before and it ended up being a corroded out start stop line in the connectors . Cut till the wire looked nice again and spliced it back together .now it works fine . But I would be going perfectly fine and it would shut off randomly and sometimes it wouldn't even start back up again.but it would turn over still..
