650sx w/a 750sxi vs. a 750 sx w/ same motor
Well I'm stuck without a ski after a friend ran my rideplate into the bottom of the ocean. ripped all the inserts out. carnage. Well i guess that hull was falling apart under me anyways. too many stress cracks and a patch job i didn't notice when i bought it.
So heres the question i'm posing.
I just picked up an 88 650 sx hull custom paint job 0 stress cracks and footholds, ocean pro ride plate everything else is stock.
I also have the opertunity of picking up a 93 750 sx that needs paint o stress cracks all stock
either hull will get the transplanted 750sxi motor
What i know
after riding a sxi i liked it but it seemed a bit heavy
750sx =340 ish pounds
650sx=282lbs.
??? never rode a 650sx
now with the same power (75 horsy's) which ski would you guys recomend for wave jumping and freestyle.
before you say it, no superjets!, unless the sxi motor will fit?!?!:banghead:
simplified what hull should i use. and if the 650sx. what prop/ impellor do i use
KaosFreestyle
White on White
Mequon, WI
I have a 650sx. So I am somewhat biased in thinking that their are better boats out their. I think the SXI is better just because it looks sleeker. Something about the height of the 650 handpole turns me off and also the curves of the SXI is much better. Though Ive never ridden a SXI or anything else for that matter, the 650 just feels incredibly heavy.
SX it has the best bottom for freestyle. The chines are shallow. Yes, a little heavier, but the rotation abilty of the 750 ove the 650 makes up for that. Just slap some footholds and a scupper in the 750 and look for a Factory limited pipe. There is one on Ebay , but they are calling it a Mariner. Done.
