650sx wave jumping build?
Hi i have a kawasaki 650sx and it is bored out to 670cc it has a 44mm carb on it. It also has umi 0 degree handlebars with finger throttle. And it has a wet wolf freestyle cone.
I am planning on buying:
500 gph bilge pump (not sure which switch... any suggestions?)
Handle pole limiting rope.
hood straps.
What else do you recommend i put on my ski?
Thanks
randalj1
F.F.L.F. is why im here
Chisago City, MN
As for the bilge switch, I bought the non handlebar $40 switch from blowsion and mounted it on my dash of my 650.
I think a lower pitched prop would help out. I am running a Skat 10-18.
i ended up ordering:
Hood straps
Handle pole rope
2 rule 500 gph bilge pumps
tow loop
Two black straight fittings.
A universal kill switch with lanyard and a bilge pump switch on it.
lifter wedges until i get foothold. (out of money :/)
and 2 3ft bilge hoses.
Thats all for now :)
am i missing anything?
and how do i connect both bilge pumps to one switch?
and where should i put the 2 bilge pumps?
Thanks
Mark Gomez
is where the surf is
Fullerton, CA
to connect the two bilges crimp the two positive wires of the pumps into one or separate and mount them to your positive line of your battery or where that positive battery cable leads to your E box. Then for your ground crimp those two together also but that ground connection will go to your switch then the other end of the switch will connect to your actual ground. sounds complicated but the switch just connects and disconnects the ground connection between your bilges and your actual ground. make sure to also do loops with your bilge hose or water can seep through if your pumps aren't on and the exit nozzles are submerged.
other than that dont worry about foot holds with hood straps and some kickers your good to go just ride ride ride get used to it and get your basic surf riding and tricks down. then if you want go with foot straps and do the epoxy nut and washer trick to mount them dont screw them in your you will be screwed... ha pun
like me with a heavy saturated foam 550
cookerq62
Life's Been Good
Upper Bucks, PA
Secure that plug in the hood. If you land hard it will pop out. Sell that nose piece cus its gonna fall off. I think Atlantic jet sports sells a good replacement.
