650/X-2 650sx with kerker pipe cooling line help
Hay guys sorry to bring up something I'm sure has been around 1000 times but I can't find any info on how to run my cooling lines with this new kerker pipe.
I see there's kerker pipes with two nipples and three, mine has two one to the top of the pipe by the head and one on the back side of the elbow. Ik that on the stock pipe the fitting on the back of the elbow
Went to the built in overflow in the hull would this be the same? Any help would be amazing I want to hit the water tomorrow. Thanks a ton guys
the fitting on the head pipe closest the the exhaust manifold goes to the fitting on the head. the second one goes straight into the stinger, with a T fitting that goes to the pisser. Good luck!
Stockton
The other thru hull fitting that had a hose going to your stock pipes elbow that dumps into pump area, cap it off in the engine compartment. The cooling water supplie line from the pump goes to the bottom of your exaust manifold, the other end is connected to your pump. I have pic if you need them
