- Western NY
A couple guys asked about these after I made a one off one for myself seen here: https://www.x-h2o.com/threads/66e-conversion.198714/page-2
Planning on a run of 10 or so in the next month or two. I've changed the design somewhat with some stuff I learned on the first one:
I changed to 3 pieces after talking with @senor and @DylanS to accommodate different chambers jut by changing the "snout" piece.
Moved the chamber interface slightly forward
Added more water jacket, and moved water inlets away from motor. Original front water fitting hit starter. I plan to tap both top and bottom so water can be fed from either side.
What do you 66e guys think? What else should be changed before cutting these things?
Pics of rev 2:
Pics of rev 2:
