yes sir stocky cut down a looot!Stock hull?
That 750 is seriously chopped up. BF is going to take more technique, head back, extend legs, pull back. The L shaped turn looks like it produces a decent setup, but the U turn usually makes a better wake. JMO, I only flip in the surf...
get the back end lower on take off. You want the pump hooked up as much as possible. This will get the ski/nose more vertical before you even get the tail out of the water.
I would say practice the u turn and getting the back end to sink at the bottom of the setup wake. If you do not accelerate once the back end drops down, the wave should at that point push the ski on top of you. This would be when you have the perfect setup and ski position to move to the second part of the BF.
Good luck,
And please the day you land it, ride it back and pop the hood to show everyone whats inside. I think you'd be the first the flat water flip a 750sx. You can do it man
thanks. yea im really happy with it. its come a long way from when i got it thats for sure..i have a ocean pro head. i flipped the exhaust to the other side so i dont run a waterbox. little porting and thats about it other then whats listed on my comment on youtube. total loss is what gave me the best gains other then the pipe. i just added the tbm. and dual carbs. its def helping with hook up for sure and def some more pop of the bottom.
what do you have done?
