Hi guys this is my first post on here, it seems like there’s many credible people on their forum so wanted to throw a problem I have out there. I have a 1992 750sx with a fully rebuilt oem engine, 170psi, coffman rocket pipe with inline silencer, SBN 44.
I have constantly had this starting problem and can’t figure it out for the life of me. The ski has a good flywheel with all teeth, new stator, good bendix, good starter. I also have replaced the starter relay, cdi with a wsm one, ignition coil and regulator have also been replaced. Battery is brand new and is good.
When I start the ski it hesitates and pauses until it starts, but it starts everytime. I should note that I can have the spark plugs in with the caps off and it turns over great, but as soon as I put the spark plug caps on and give the cylinders spark it has the pause hesitation sound before it starts. if anyone has had the same problem or knows what going on, I appreciate you very much. Thanks
