- Bay Area/Eugene
Heres my issue, i picked up a 94 750sx bone stock fairly clean, and it had a god awful top end prop on it, no low end torque whatsoever, I take the air filter off to replace it with a prok filter, and in doing so the gasket between the manifold and carb slipped between the inlet and would only allow the throttle to move at about 1/4 throttle (rookie maneuver yes), after figuring this out 5 feet past the dock i bring back in to fix it
so I managed to get it back into place and she ran like a lawnmower very slow, only a consistent bogging, no matter how much throttle i gave her, not even fast enough to get on plane, about 5 mph, then after 10 minutes of that, it started to have abrupt RPM gains for about a second, which consistently increased in occurrence, till it started to run normally, this is was also in high altitude
then when i brought it back down to sea level, i installed a stock 800 prop, and took it out to the local marina and low and behold the same BS, ran like a lawnmower for 10 minutes, no matter how much throttle i gave her, but was able to get on plane and get her going at decent speed, but just a consistent drone of the motor, then the abrupt increase in revs started after i would give it 1/4 throttle for 10 seconds let off and then repeat and then the revs would increase in occurenece and eventually run good
i would appreciate any help at all...
