Just a quick question. Is there a decent exhaust for this ski that won't break the bank anymore? I've done tons of pump/hull mods, but I am debating trying to get my hands on a pipe to wake her up more.
Get a FP limited pipe, Its worth waiting for. The dry pipes and other wet pipes like coffmann and R&D work well too but wont bring the same level of performance as the factory performance pipe
Pipe was my best bang for the buck upgrade. What ever used one you can get your hands on cheap is probably worth it... Since you said not break the bank. But the Factory Pipes are expensive for a reason. AWESOME.
On SX the Factory limited seems to be the preferred PIPE, and with a 9/17 Prop Woke mine up Quite a bit. Better throughout the power band. And easy to install.
It did not produce the same result on my SXi Pro...
