The short version of the above assuming you know what you are doing...
...Install primer nipple on carb
...Cut reserve line and put in the provided T
...Run included hose line from T to primer pump
...Run included hose line from primer pump to carb
...Zip tie all hoses
You carb needs a primer fitting. It should be included in the kit. It is the small nipple that is included. I have never put one on a carb so I cannot give you the exact steps. I do know that one way is to remove the stock choke butterfly and use the hole left behind for the nipple, and the other way is to leave the stock choke alone and tap the carb somewhere to add the fitting. My carb had the fitting, so again, I cannot give anything more specific as to how to install it.
Once the fitting in on the carb, you do the following...
Find a location for the primer pump. Where you install it is your decision. The most common place is to use the hole left over from the stock choke cable in the front of the tray. Now that you have decided where the pump is going to go, pick a place in the reserve line for the brass T included in the kit. It does not matter where you put the T, but the shorter your primer lines are, the less fuel you need to pump into the primer system before it actually puts fuel into the carb. Next, figure out which nipple on the primer pump is in, and which is out. You can do this simply by putting your finger over the nipple. If you have the pull/pump kind, it should pull air when you pull on it, and push air when you push on it. If you have the ball style, then it should pull air when you press the ball and push air when you release the ball. If in doubt, just hook it up and if it doesn't push fuel it's backwards, so switch them. Now that you know how it all works and goes together, repeat everything list above to make sure you are 100% sure you have a plan. Once you are sure, cut your reserve line, install the T fitting (the fuel line stays straight, the 90 degree angle is left out for the primer pump). Attach the included smaller fuel line to the base of the T, run it through the nut that holds the pump on, through the hole in the hull for the pump and attach it to the primer pump (don't be lazy, run your primer lines nicely around the outter edge of the engine compartment) then cut off the excess. Next connect the fuel line to the out on the primer pump, through the hull, through the nut, (run it nicely like you did the 1st line) and attach it to the new nipple on the carb. Make sure all connections are zip-tied in place. The fuel selector MUST be set to "on" (NOT reserve) and test your pump. If it does not work, switch the hoses on the pump opposite that you have them (after making sure you do not have the fuel selector on reserve. You must have a fuel selector and it must be set to on).
