Ok, thought I would repair some damage I did last year, when I was putting on my new intake grate I stripped the threads on one of the holes, so being that I was lazy and wanted to just giv' er, decided to silicon the stripped hole and ride with three bolts on the intake grate. This year I took off the intake grate and found water that the front two holes, the one's closer to the engine compartment leak a bit of water, and if I blow air in one hole it will blow out the other hole. How likely is it that the water is coming from waterlogged foam in the tray?
