- Green Bay, WI
While rebuilding my 6M6 into a 61x/62T I noticed the midshaft side coupler has stress crack in it. I would like to get a new set of couplers and just need to verify that while changing the coupler I will also have to change the midshaft, correct? Is this becuase the 650/701 midshafts are different diameter/thread on the end but the overall shaft lenght and diameter are the same so I can press it into the 650 bearing carrier? The bearings in the carrier seem very smooth and near zero runout.
Matt
Matt
