- McHENRY IL
I have a 96b1 that i am having trouble tuning the carbs, i am new to carb tunning and am compleatly lost1
I have the machine set up with fresh bore 81.5 mm pro x pistions ,ada head 35cc domes with girdled head factory pipe limited, dual cooling, solas 144 mag pump,hooker 10/16, tuceti filters , riva grovy and intake , lightened flywheel , 62t igniter, GROUP K air fuel seperator, tiny tach.
the carbs are stock 38 mm with the chokes 72.5 low 140 high 1.5 needle and seat, gold springs pop off at 55.
the problem i am haveing is that the machine will not go wot 75% / 100% rpm instantly drops.
i have tried diferent jets but it seems to always go lean as if there is not enough fuel in chamber...
any ideas im stumped????
