97 Roundnose "Resto Mod"
Mike W
Infidel
North Florida
I'm not really doing a build thread but I just wanted to post the progress on my current build. I picked up this hull a couple months ago and intended to just install footholds and go but the graphics were not in very good shape and the hull had a couple issues that needed to be fixed. So I bit the bullet and started a full on resto mod restoration on it. My plan is complete paint top and bottom, stock reproduction 97 graphics and footholds. I will be replacing all the purple trim with black trim. It's pretty much going to look like a new ski. Anyway, below are pics of the progress.
This is what it looked like when I bought it:
Mike W
Infidel
North Florida
I used a single stage urethane and it came out very nice. Very close to the look of gel coat which is what I was trying for.
Mike W
Infidel
North Florida
The top deck had a couple spots that were caved in so I wanted to fix those areas. I cut the holes for the footholds and defoamed the problem areas. After a little heat was applied I used a jack and blocks of wood to push out the hull. Worked like a charm.
Mike W
Infidel
North Florida
Top deck prep done and in primer. So many hours of sanding to get it right. Glad to finally get it to this point.
Mike W
Infidel
North Florida
Got the pole, bracket, spring and steering cable in. Working on steering, throttle cable and s/s switch today. Monday I will be starting on fixing the warped tray.
Mike W
Infidel
North Florida
Thanks fellas, I know my wife is ready to get done with this project.
Cut the tray yesterday and the foam was dry as a bone. I hope to get refoamed and glassed up today.
