Super Jet 99 superjet loses spark when i shut it off after ridding please help
so after about 30 min of ridding ill shut my ski off and it was running great no bogging or misfire and then when i go to restart the ski shortly after i have no spark until i get it cooled down. i have tested the kill switch its fine and i took apart the e box and found water in it so i took everything apart and cleaned a everything went out for a ride and same symptoms the stator was bone dry pleas help Thanks Dan
523 ohm for the charge coil is still within specs, but may not work with a MSD enhancer. Yes it could be your coil, however a stator reading can- in rare instances- give you a false positive (after it heats up during use)
