Super Jet A good place to buy trailer bearings
I thought i saw a thread on here about somebody changing out the cheap bearings with some decent ones. I was wondering if i needed a certain part number for the bearings and seals.
Sent from my DROID X2 using Tapatalk 2
Should be standard sizing, 1", 1 1/4" etc. etrailer or easternmarine are good online sources.
They aren't-
They are bearing # 30205 25x52 mm, I bough some from ebayer irvineman, $15.54 shipped per pair.
The seal is 30X52X7, You could probably use a little wider or narrower if you wanted to.
Use high quality seals, the ones your trailer came with are junk.
Next time I may try sealed roller bearings, I hate how messy servicing tapered bearings is.
EDIT: KTM part #0760305271 is a high quality replacement seal for about $4
Thanks for the info suva! Was it you that had the thread about the trailer. I couldnt find it. I thought it was you but I wasnt sure.
Thanks again for the info
