ABLE cylinder Questions
Hi guys, I recently signed up for this internet page and this is my first post, I am writing from Italy.
I recently bought a wave blaster with cylinder and cylinderhead able.
Now I need to change the pistons and pistonring but I can't find the new spare parts suitable in Italy the code for the piston is 635P2 TD (wiseco piston)
Maybe someone in this group could help me thank you very much in advance.
(Excuse me for the possible grammatical errors )
Jr.
Standing Tall
Staff member
Hot-Lanta
Welcome to the X!!
If I'm reading it correctly, It should be a regular 81.5mm Wiseco piston for the Yamaha twin 701
actual Wiseco part number 790M08150 I'm sure you can source this, or a equivalent Pro-X piston in Italy
If you cant? I'm happy to ship these to you. I stock Pro-X and Wossiner pistons in this size
BUT! disassemble cyl, and check bore? if cyl is showing significant wear, I would suggest boring up to 82mm
P
Welcome to the X!!
P
Thank you so much check and I'll give you updates
I found in my garage an old piston wider than 0.50 (wiseco Numbers: 790M08200 but I am noticing that it is slightly higher than the one mounted in the able cylinder and also heavier. could it be that these differences are present due to the 0.50 wider size??
Jr.
Standing Tall
Staff member
Hot-Lanta
Looks like cast vs forged pistons??
Measure piston timing dimension to verify?
( top wrist pin bore to outer rim piston crown)
Jr.
Standing Tall
Staff member
Hot-Lanta
I now see #HPEMatt is back on the site
Good to see this Matt!
Ill turn this over to him, as he is the man behind Able. He will be able to supply you with everything you need
I'm sending more photos of the pistons, maybe someone can help me find them, I'd be very grateful.
Hi guys, thank you all for the advice, I managed to make the engine run with the new pistons!
Now I found a problem for the engine head that OR can I adapt ??
Quinc
Buy a Superjet
California
Do you need new orings? It is most likely one of these:
  • 9464K341 Viton O-ring As568a Dash Number 034
  • 9464K141 Viton O-ring As568a Dash Number 141
Thank you so much.
