- clearwater, fl
I have an 01 superjet that i just bought and it has a r&d rev pipe on it. There is a solenoid valve that controls the water flow to the pipe and it is not opening.I traced the wires from the valve back to a little black plastic box that has a yellow wire that comes out and wraps around the spark plug wire and it also is connected to the battery. It is really simple to bypass the valve so i was wondering what you guys knew about it, what its for, and if i should or shouldnt bypass it? And i was also wondering if you knew of a place were i could get one? Thx guys, Steve
