AC or UMI sj pole?
skysurfer2010
SUR 24
Philly
Which one is better? I'd be getting either in -2". I'm limited to those two poles since they are the only ones i can get at cost from work.
Do either need anything else to be mounted? I already have a UMI standard height pole mount and UMI steering.
Frosty
New York Crew
Western New York
I use a -3" AC pole, but that seamed to be poorly made IMO. My next pole will be an X-Metal for sure!!!!
Oh, and you shouldn't need anything else to mount on the UMI bracket. Either will work... you might want an aftermarket spring though.
D Slicker
Durham, dont forget it
Pottstown, PA
I just put a -2 X-metal pole on my SX-R and it rocks. I am either going to corsans inlet or barnaget this weekend if you want to try it out.
P
PancakePete
Guest
Greg. Xmetalworks.com Those Poles and stearing put you in great body postition for alot of tricks. I have on been on my new boat twice and already notice a difference of my riding improving.
D slicker, Surf is great. If you rip. let me know. I am hitting seaside on Sat. and maybe sunday too... :biggrin:
D Slicker
Pottstown, PA
Ill call ya tonight.
skysurfer2010
SUR 24
Philly
thanks for the invite man, but i have to work tomorrow and i have to work on modifying my double trailer into a triple sunday.
will the x-metal pole bolt up to the umi bracket? or would i need the x-metal bracket?
Tuscaloosa, AL
you could, but spend the extra $100.00 for the bracket to get the full benifit of the setup..
skysurfer2010
SUR 24
Philly
hmmm i think the pole will have to wait until after lanier then. i forgot i'd need a chinpad too. hopefully the stock pole will hold up until then.
