SXR AC SJ pole on sxr anyone
Ive been trying to research this but im not getting a clear answer. what all needs to be done for the swap. I know you need the steering cable bracket off blowsion but what else to make it work? will my quick turn off my sxr work on it? does it just bolt on to my handle pole bracket?
Sit
UK
I run an AC SJ pole on my SXR - as younalready said it throws the cable a different direction so you need the Blowsion bracket (although we managed to fabricate our own) the quick steer won't fit as far as I know and you will need to run an upside down SJ system.
Once fitted it all looks very good and neat.
Si
Sit
UK
Yes bud here's a pic of mine fitted -
Si
Kawikazi
Don't follow my line.
NRG, WV
I made a spacers for each side of handle pole and used the factory bracket and bolt. I then drilled and tapped the opposite side its the yamaha turnplate and wha-la.... looks great I'll admit. Much better than AC's kaw version of the pole.
Hey Moto X if you do this conversion to your SXR think you could post up some pics? I am interested in doing this as well but want to see some pictures!
