Hi guys,
Does anyone have any reccommendation on foot straps that are adjustable, of good quality and are big enough to use when wearing shoes? I don't really like bare foot riding, it just feels wrong.
I have the Dakine Supremo and the Core Contour, but neither of these will work. The Supremo can be adjusted, but the outer neoprene housing gets in the way when trying to wrap it around the strap. The casing is the limiting factor here.
The Core Contour has solid molded (45 deg) mounting points so you can't stretch it out enough to mount it and get a foot in under there. Especially the case when using a thick underpad.
I was thinking that the Proform might be the way to go. It looks just like the Supremo, is adjustable and doesn't have the outer casing on it. More than anything I just want something that locks my feet in and it adjustable for when your shoes soften up, or the turf and underpad strarts to compress a bit. I was also thinking of mounting the straps on some spacers so they didn't have to pull righ to the bottom of the tray. It's high on my list, but would like some opinions on straps if anyone cares to share?
Thanks...
Thanks...
