Freestyle adjustable 144 nozzles
I built an 800 HX that had adjustable nozzles on it and it was an awesome tuning tool to have. Being able to change the rings out and tune the pump was great. This winter I am going to build a brawler hull. I would like to be use a 144 solas pump and some adjustable nozzles. I started to search but there isn't much info for adjustable nozzles for the 144.
Are the solas nozzles the only ones to go with? opinions on the solas nozzles?
I guess anyone have some for sale?
dfw
Nozzles were never a very popular modification so there is not many choices. Solas nozzle is a stock copy. Stock nozzles start at 81MM and can usually go to 84MM. Old Protec nozzles are thick enough for 88MM. Sato made a nice one but are difficult to find. For freestyle use a 62T nozzle bored to 84MM or a Protec bored to 85-86MM and adjust the impeller accordingly. Make sure to get a short cone with that Solas pump because the long one is in the way.
I guess a little details on the ski. php 4 mil 789cc, pump gas, total loss, 46 novi, atp toploader, solas 144 mag not sure exactly what I am going with for the following but Zack and I have an idea. Anyone have a similar setup already on the water?
pump cone-
reduction nozzle size-
steering nozzle size-
hooker impeller pitch-
If I find a solas trim setup I could always go up to John's and see if they fit its only about an hour. Need to find a trim system first
