DAG
- Charlotte, NC
Is this only advantage of a pump dump is to save the scupper flap?
Don't some people have problems with scupper valves getting damaged by continually landing on the tail? Is that a reason to move the scupper into the pump area?
ok, understand if your running a one way or scupper on the exhost side that it turns into the pump.
any advantage to turn a oneway into the pump instead of going out straight the back on the left side of the ski.
Scuppers in the pump SUCK!!!! My last ski had one & I blocked it off with a Ball on the engine side. It always leaked more, I don't think there's enough pressure to keep it closed. Plus once it gets a zip tie stuck you gotta pull the pump out to remove it.
Pump dumps, suck!!! One scupper is perfect
