Advent Q's ?
njfl
X-H2
I run D15, Curve 2 in my Superjet:
1500-5000: 28
5250: 26.5
5500: 25.1
5750: 23.7
6000: 22.3
6250: 20.4
6500: 19.5
6750: 18.5
7000: 18
7250: 18
7500: 18
7750: 20.5
8000-up: 23
njfl
X-H2
Thanks, How modded is your ski ?
Very.
No, actually, it is quite conservative in porting.
933 ADA cylinder (7mm), Jetworks porting, dual 48 Blackjacks, B mod pipe, 140mm pump.
If I reduced the compression to around 150psi you could run premium pump gas (what I am getting at is that you don't need to run race gas because of agressive timing).
shepster
Living the dream!
This is where my Blaster is : Freeride ported 85mm 61x, ported 61x cases, b pipe limited, ada head 185psi, single 49 full spectrum etc.
Running straight Av gas at the moment
What curve would you suggest ?
njfl
X-H2
I'd suggest a curve with the same profile/shape, but maybe starting with a little less initial advance.
But, for the best fit curve, talk to your machinist.
Who did your porting? I would ask them what timing curve they would suggest (like if you had a fully programmable ignition). Then, talk to Greg at Advent and ask if he has one close to that. I bet he does.
Watty
Random Performance
Australia
I always used the following curve on a limited setup with extnsive porting. This curve is great for freestyle, but if you are running a dry pipe, or plan on racing it, you might get Advent to re-program the curve so it starts to drop off at around 4 - 4500k
