Ok, I’ll bite:what way is better?who couldn't align it any other way.
Taking a actual mid-shaft. Pulling the shaft. Using that instead of a cf alignment tool. Getting it set. Then marking the outside edge with a pen. So you can get it back in the exact spot.Ok, I’ll bite:what way is better?
Ps, i have not experienced 1/8” play in the mounting holes of either the alignment tool or actual midshafts, nor the combined worst case play.
It just one of many tools we can use....... It does nothing for aligning your motor. You till have to align your motor to the midshaft and pump. It is just a tool that helps with getting your pump aligned with Midshaft. You still have to check everything even after you use the tool.......Moving the shaft 1/16 of an inch in the wrong direction. Would throw alignment off enough to feel a vibration. There is no way to use a tool to align. And then use a midshaft. And get then in the exact same position. Unless they are the exact same shape and size AND you make a mark before you remove the tool used to align.
I'm not saying the tolls don't get skis on the water. I'm saying using a midhsaft and taking the time to do it right. Yields better results.
The shaft and pump alignment are dependent on each other. The motor is independent of the 2. Relying on the cut hole in the hull, to be exactly center. Is a recipe for failure. Even on a sj hull. Look at how the bulkhead is glued in. You think they got them all in the exact same spot? The cf tool just gets the alignment set to the tool and the hole in the bulkhead. Using an actual empty midshaft let's you see where the shaft should actually sit.It just one of many tools we can use....... It does nothing for aligning your motor. You till have to align your motor to the midshaft and pump. It is just a tool that helps with getting your pump aligned with Midshaft. You still have to check everything even after you use the tool.......
Harrison township. On lake st ClairPs, where are you in MI?
Weeks brothers one. They 3D print themWhich tool did you buy? Show photo, please.
The one I got yesWeeks brothers on here makes that tool for the SN, it is the one I have.
Then, yeah, it's approximately as simple as I said above. Shimming the pump gets you vertical alignment, but side-to-side alignment requires just moving the pump within the slop allowed by the pump mounting bolts, the pump seal, etc. I think I'd remove the midshaft and pump install guide/tool and install the pump+seal completely with no shims, just to see how far off you are at the start. If it's close enough that you can install the guide/tool without damaging it, then do so, and then shim the rear pump mounting bolts to get vertical alignment. Once happy with that, partially loosen all but one of the forward two bolts and twist the pump to get side/side alignment. The bolts need to be loose enough to allow adjustment, but not so loose that they won't hold your adjustment. Retighten and double check. Repeat til you're happy. There are decent videos on this, but I couldn't find them quick, sorry.Weeks brothers one. They 3D print them
