ALPHA BETA CHARLIE DELTA
Built these cart/carriers.
The first was Alpha, built in 1995, for my FX1.
It used a steel hitch piece for about 5yrs, till it started to sag (salt water).
So I upgraded to stainless about 18 yrs ago, no problems since.
Alpha works like this:
Single pin retains it to the hitch piece.
About 23 yrs, doesn't owe me a dime. Used it with both FX & SJ. Going to am hull figured time for an upgrade.
Welcome Beta & Charlie. They were built this configuration.
Did not feel like welding , really just wanted to do this:
Only kidding, had to do this:
Being bolt together has advantages , compact storage.
Based Beta & Charlie on modular construction, repeating pieces.
Came up with mast piece to hold hull:
And this pin for the u bolt:
The main spar is heavy wall stainless, the cart interface is thin wall. I didn't want to drill into the heavy wall by the hitch so I re-purposed my cart leg sockets for a box clamp. The bolt on top only goes thru the thin wall.
I found this awesome capstan/winch that uses standard boat lines. You can bite the line anywhere you need to. I got a short one for pulling onto the cart if I need to, and a long one for pulling to the truck. I can drop the rear leg for surf/dead ski recovery.
