Other Alternatives to using plexus for inserts
I (or rather Whitca) have used tee nuts as inserts that were affixed to the hull with gradually larger pieces of glass and/or carbon. Works great and looks clean.
Just cut a hole for the insert into those pieces and block the threads.
McDog
Other Administrator
Staff member
South Florida
Me too. Cheap and easy and stronger than anything else.
D
Danman108
Guest
I personaly like g/flex that :):):):) has crazy stength I belive it says 150,000 psi tensile strength per squar inch
